Handguards (proteggimano)
Inviato: domenica 28 marzo 2004, 1:24
da f_capo
Hi,
i tried to fit the BMW 1150 GS handguards on my Capo.
But they don't fit well on the clamps. It is a bit difficult to explain but i have to force the handlebar to make them fit on the clamps.
It looks like the handlebar shape is (too) different from the BMW's.
Is it normal force must be used?
thanks
Filip
Inviato: domenica 28 marzo 2004, 21:01
da paolo299
Hi Filip!
Go on site home page, after in "officina Caponord", you'll find some interesting photos on "paramani originali BMW...".
It's normal to force a little bit the handguards.
Bye Paolo
Inviato: martedì 30 marzo 2004, 1:46
da f_capo
Hello
the handguards are installed now.
I had to fix them first to the clamps when the steering weights were removed. Then it was quite easy to get it right.
Only small remaining problem is the left one touches the tank slightly when in locked position. But i will adjust the handle bar a little.
Filip
Capo 2003
Inviato: mercoledì 31 marzo 2004, 17:09
da attila
f_capo ha scritto:Hello
Filip
Capo 2003
Good job Filip!
yes, as far as I know also the others had the need to adjust a little bit the handguards to perfectly fit the handlebar parking position and avoid touching the tank...
