Fuel level Indicator
Okcbo
Moto: Pegaso Strada 2005
Messaggio da Okcbo »
Hello,
I realize that, on my new Strada (I bought it one month ago), I never saw the fuel level indicator. The left of the screen is empty.
The light for the reserve works when I turn the key, but that's all. Any ideas ?
Re: Fuel level Indicator
Maybe the sensor in the tank is disconnected? Try first with WD40 in the connectors, maybe is just a bad electrical contact
Okcbo
Thanks. You talk about the fuel pump connector ?
Yes, that one.
Okcbo
Ok. It doesn't work.
So I think I will have to open the tank now...
But how can be sure that it is not a screen problem ?
Well, it could be a screen problem, but before going that way (than you should send the dashboard to Androidx, for instance) I would check everything else, and exclude other possible causes
Okcbo
Many thanks giamaica.
are you sure is a Strada dashboard,
not a Trail one?
Okcbo
C'est la question qui me semble être la bonne ;)
Lupo motociclista
NUOVO STAFF
NUOVO STAFF
Moto: Pegaso strada 2008
Prova a collegare il piedino 9 del cruscotto (filo nero/arancio) a massa e vedi se compare l'indicatore del carburante
Okcbo
Grazie Lupo !
