Allora, declino ogni responsabilità ma posto perchè sembra interessante.
Roba presa da facebook, postata da Steven Chua (a cui ho chiesto e che ringrazio per aver postato foto e descrizioni), chi si vuol cimentare e volesse aggiungere foto è il benvenuto...
Non me ne abbiate, ma posto tutto pari pari, senza neanche tradurre, ma google translator è lì che aspetta, quindi...
1) Smontare il cruscotto dalla moto
2) it had no screws just a clips but you must remove the water proof silicone 1st in order to open.
3) after open the front now remove the back.
4) to remove the back becareful the LCD ribbon.
5) Now everything is removed u must remove the needle.
6) Using a special tools which Aprilia factory did not provide me the part number.
7) remove the facia
8) remove the LCD slowly please study and understand the latch and the way to remove. Broken LCD is not my responsibility.
9) now everything is open u can see and fix what u needed
10) the backlit led is behind here
... CONTINUA...
MANUALE FAI DA TE - SOSTITUZIONE LED E EPROM CRUSCOTTO
Ultima modifica di giamaica75 il mercoledì 9 giugno 2021, 19:09, modificato 1 volta in totale.
Re: MANUALE FAI DA TE - SOSTITUZIONE LED E EPROM CRUSCOTTO
... CONTINUA...
11) disolder this 2 points
12) you can see this is the led strip
13) to remove the led u need to cut the latch
14) now it had been removed
15) remove all the led and replace with 0603 or 0402 led
16) this is cluster backlit led
17) the eeprom for the immobilizer.
18) replace this 4 for background. The 2 more is for the needle.
19) always observe the polarity by noticing the LED notch.
20) after replace remember to clean the board with IPA.
... CONTINUA...
... CONTINUA...
Ultima modifica di giamaica75 il mercoledì 9 giugno 2021, 19:06, modificato 1 volta in totale.
... CONTINUA...
21) Testing the back-light LED 22) remove the AT24C16A eeprom 23) read it and save the original file incase you have a fankuxx day. (reader: XGecu software) 24) Select the correct parameter to read 25) make the 00 00 00 as the red one u can see 26) write it back and god bless you 27) enter 00000 and pray to any universal biker god that exist. 28) seems like it is working... maybe the top row of the hex is for factory code and bottom is user code so all is now 00000. 29) seems working fineeeee.....
