presto in vendita su http://www.palmerproducts.co.uk/
This Screen Adapter Kit is designed to address the common issues of wind, noise and turbulence to significantly improve the bikes cruising and touring ability, providing the rider with a much improved riding experience.
The Aprilia Screen is quite a good design (although positioned incorrectly) so we recommend this in conjunction with the Adapter Kit
The key to optimum performance is the forward position of the screen, just enough to allow air to pass underneath, relieving the vacuum created behind the screen - the main cause of turbulence.
This forward positioning also provides essential airflow to prevent visor misting and fogging.
Provides 60mm of vertical travel with up to 15 Degrees of tilt.
The fitment of this kit requires NO MODIFICATION to the bike and fitted in minutes.
These unique and original Kits have become extremely popular amongst the Adventure Rider community all around the world!!
The Benefits of this system also include:
* Kit comes Preassembled, ready to mount to the bike using existing locations.
* 12 indexed positions (height and tilt angles) - giving all the range of adjustment you'll need.
* Top grade Laser-Cut Stainless Steel brackets and Stainless Steel fasteners.
* Kit comes complete with all hardware and tools, plus spare sundries.
* Allows cleaning access behind the screen without removal.
* Can be fitted in approximately 15-20 minutes.
* On-line step-by-step detailed digital photo instructions.
* Tool-less upgrade available for quicker screen adjustments.
[/img]
