attila ha scritto:
ehm, visto che il supermarket funziona bene... e una bella dinamometrica 5-25 N con attacco da 1/4"?
A quanto la scoveresti?
Posso trovarti in Germania una dinamometrica ottima della PROXXON
www.proxxon.de di seguito alcuni particolari e foto.
Però, se ti serve per CN, cosa ci fai?
Le coppie più "frequenti" nella manutenzione vanno da 20 a 100 Nm.
Fammi sapere e mi scateno....
High accuracy according to DIN/ISO. Bigger, more easily read scale to exactly adjust to desired torque.
The changeover mechanism allows left and right hand threads to be tightened. Reaching the selected torque is indicated by an audible and detectable click. The grip adjusts to set the selected torque. Securely packed in a practical case.
MICRO-Click 200/S
With 1/2'' square drive (switches over for left-hand thread) to DIN 3120. Torque 40 - 200 Nm, otherwise as detailed above.
NO 23 353
MICRO-Click 100/S
With 3/8'' square drive (switches over for left-hand thread) to DIN 3120. Torque 20 - 100 Nm. Ideal for motorcycles. Otherwise as detailed above.
NO 23 351
MICRO-Click 30/S
With 1/4'' Square drive to DIN 3120. Torque 5 - 30 Nm. For screws of all kinds up to M 8 (13 mm) Otherwise as detailed above.
NO 23 349
